#include "stm32f10x.h"
#include"12864.h"
#include"delay.h"
//FILE:液晶12864驅(qū)動程序
//DATE:2012/07/11
@f_name: void LCD12864_InitPort(void)
@brief: 初始化硬件端口配置
@param: None
@return: None
GPIO_InitTypeDef GPIO_InitStructure; //定義結(jié)構(gòu)體
RCC_APB2PeriphClockCmd(GPIOCLK|RCC_APB2Periph_AFIO, ENABLE); //使能功能復(fù)用IO時鐘,不開啟復(fù)用時鐘不能顯示
GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE); //把調(diào)試設(shè)置普通IO口
GPIO_InitStructure.GPIO_Pin = LCD_GPIO_DAT; //數(shù)據(jù)口配置成開漏輸出模式,此模式下讀輸入寄存器的值得到IO口狀態(tài)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //開漏輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(LCD12864_GPIO , &GPIO_InitStructure); //IO口初始化函數(shù)(使能上述配置)
GPIO_InitStructure.GPIO_Pin = LCD_GPIO_CMD;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
GPIO_Init(LCD12864_GPIO , &GPIO_InitStructure); //初始化IO口配置
GPIO_Write(LCD12864_GPIO ,0xffff);
@f_name: void NOP(void)
@brief: 延時函數(shù)
@param: None
@return: None
void NOP(void)
{ u8 i; for(i=0; i<100; i++); }
@f_name: u8 LCD12864_busy(void)
@brief: 檢測忙狀態(tài)
@param: None
@return: None
u8 x;
LCD_RS(0);
LCD_RW(1);
LCD_EN(1);
NOP();
NOP();
x=Text_Busy;
LCD_EN(0);
return x;
@f_name: void LCD12684_Wcmd(u8 dat)
@brief: 寫指令
@param: u8 dat 輸入指令
@return: None
while(LCD12864_busy()); //忙檢測
LCD_RS(0);
LCD_RW(0);
LCD_EN(0);
NOP();
NOP();
LCD_WriteData(dat);
NOP();
NOP();
LCD_EN(1);
NOP();
NOP();
LCD_EN(0);
@brief: 寫數(shù)據(jù)
@param: u8 dat 輸入數(shù)據(jù)
@return: None
void LCD12684_Wdat(u8 dat)
LCD_RS(1);
LCD_RW(0);
LCD_EN(0);
NOP();
NOP();
LCD_WriteData(dat);
NOP();
NOP();
LCD_EN(1);
NOP();
NOP();
LCD_EN(0);
@f_name: void LCD12864_Init(void)
@brief: 液晶初始化
@param: None
@return: None
LCD_PSB(1); //并口方式
LCD_RST(0); //液晶復(fù)位 低電平有效
delay_ms(3);
LCD_RST(1); //置高電平等待復(fù)位
delay_ms(3);
LCD12684_Wcmd(0x34); //擴(kuò)充指令操作
delay_ms(5);
LCD12684_Wcmd(0x30); //基本指令操作
delay_ms(5);
LCD12684_Wcmd(0x0c); //顯示開,關(guān)光標(biāo)
delay_ms(5);
LCD12684_Wcmd(0x01); //清除LCD的顯示內(nèi)容
delay_ms(5);
@f_name: void LCD12864_Clr(void)
@brief: 清屏
@param: None
@return: None
LCD12684_Wcmd(0x34); //擴(kuò)充指令操作 “繪圖”
delay_ms(5);
delay_ms(5);
LCD12684_Wcmd(0x01); //清屏
delay_ms(5);
@f_name: void LCD12864_Pos(u8 x,u8 y)
@brief: 設(shè)置顯示位置
@param: u8 x:X軸 u8 y:Y軸
@return: None
u8 pos;
if (x==1) {x=0x80;}
else if (x==2) {x=0x90;}
else if (x==3) {x=0x88;}
else if (x==4) {x=0x98;}
else x=0x80;
pos = x+y ;
LCD12684_Wcmd(pos); //顯示地址
@f_name: void LCD12864_PhotoDis(u8 *bmp)
@brief: 顯示圖形
@param: u8 *bmp 圖形數(shù)組
@return: None
u8 i,j;
LCD12684_Wcmd(0x34); //關(guān)閉圖形顯示
for(i=0;i<32;i++)
LCD12684_Wcmd(0x80+i); //先寫入水平坐標(biāo)值
LCD12684_Wcmd(0x80); //寫入垂直坐標(biāo)值
for(j=0;j<16;j++) //再寫入兩個8位元的數(shù)據(jù)
LCD12684_Wdat(*bmp++);
delay_ms(1);
for(i=0;i<32;i++)
LCD12684_Wcmd(0x88);
for(j=0;j<16;j++)
delay_ms(1);
LCD12684_Wcmd(0x36); //寫完數(shù)據(jù),開圖形顯示
@f_name: void LCD_ShowString(u8 x,u8 y,const u8 *p)
@brief: 顯示字符串
@return: None
u8 temp;
if(x>4) {x=1;}
if(y>4) {y=0;}
LCD12864_Pos(x,y);
temp=*p;
while(temp!='\0')
LCD12684_Wdat(temp);
temp=*(++p);
