樓主我的為什么只要調(diào)用void disp_sfm()這個(gè)函數(shù)就這樣,還保留開(kāi)機(jī)界面,開(kāi)機(jī)時(shí)候顯示的都正常,就是進(jìn)入時(shí)間界面這樣。≌(qǐng)指導(dǎo)!void disp_sfm()
uint temper;
uchar temper_ge,temper_shi,temper_bai,day_temp,date_temp,month_temp,year_temp;
lcdWriteCommand(0x36); //啟動(dòng)擴(kuò)充指令集,啟動(dòng)繪圖模式
ss = read_clock(0x81); //更新數(shù)據(jù)
if(sec_temp!=ss)//讀取秒,只要有改變液晶顯示也改變
sec_temp=ss;
deal(sec_temp);
if(secl!=shi)
secl=shi;
display(6,secl);
display(7,ge);
mm = read_clock(0x83); //讀取分,只要有改變液晶顯示也改變
if(min_temp!=mm)
min_temp=mm;
deal(mm);
display(3,shi);
display(4,ge);
hh = read_clock(0x85); //讀取小時(shí),只要有改變液晶顯示也改變
if(hour_temp!=hh)
hour_temp=hh;
deal(hh);
display(0,shi);
display(1,ge);
if(ge/1%2==0)
display(2,10);
display(5,10);
display(2,11);
display(5,11);
lcdWriteCommand(0x30);
dd = read_clock(0x87); //讀取日,只要有改變液晶顯示也改變
if(date_temp!=dd)
date_temp=dd;
deal(dd);
lcdWriteCommand(0x85);
lcdWriteData(shi+0x30);
lcdWriteData(ge+0x30);
mo = read_clock(0x89); //讀取月,只要有改變液晶顯示也改變
if(month_temp!=mo)
month_temp=mo;
lcdWriteCommand(0x83);
deal(mo);
yy = read_clock(0x8d); //讀取年,只要有改變液晶顯示也改變
if(year_temp!=yy)
year_temp=yy;
lcdWriteCommand(0x81);
deal(yy);
xq = read_clock(0x8b); //讀取星期,只要有改變液晶顯示也改變
if(day_temp!=xq)
day_temp=xq;
switch(xq)
case 1: dispString(3, 2, 1, "一");break;
case 2: dispString(3, 2, 1, "二");break;
case 3: dispString(3, 2, 1, "三");break;
case 4: dispString(3, 2, 1, "四");break;
case 5: dispString(3, 2, 1, "五");break;
case 6: dispString(3, 2, 1, "六");break;
case 7: dispString(3, 2, 1, "日");break;
default:break;
temper=read_temp();//讀取溫度
temper_ge=temper%10+0x30;
temper_shi=temper%100/10+0x30;
temper_bai=temper/100+0x30;
//lcdWriteCommand(0x9b); //此處可以用來(lái)測(cè)試各種紅外遙控的鍵值
//lcdWriteData(workcode/10+0x30);
//lcdWriteData(workcode%10+0x30);
if(tflag==1)
dispString(3, 4, 1, " -");
dispString(3, 4, 1, " ");
if(temper_bai==0x30) temper_bai=0x20;
lcdWriteCommand(0x9d);
lcdWriteData(temper_bai);
lcdWriteData(temper_shi);
lcdWriteData('.');
lcdWriteData(temper_ge);
(71.63 KB, 下載次數(shù): 705)
2017-8-24 08:39 上傳
(41.92 KB, 下載次數(shù): 658)
2017-8-24 08:39 上傳
