確實太難了,我改的這個程序就有問題,哪位大神幫我看看吧,P0 P1 P2口接24個LED 循環(huán)亮,顯示就是不正常
- #include <REG52.H>
- unsigned char RunMode;
- //**********************************System Fuction*************************************************
- void Delay1ms(unsigned int count)
- unsigned int i,j;
- for(i=0;i<count;i++)
- for(j=0;j<120;j++);
- unsigned char GetKey(void)
- unsigned char KeyTemp,CheckValue,Key = 0x00;
- CheckValue = P3&0x32;
- if(CheckValue==0x32)
- return 0x00;
- Delay1ms(10); //延遲1ms(10)
- KeyTemp = P3&0x32;
- if(KeyTemp==CheckValue)
- return 0x00;
- if(!(CheckValue&0x02))
- Key|=0x01;
- if(!(CheckValue&0x10))
- Key|=0x02;
- if(!(CheckValue&0x20))
- Key|=0x04;
- return Key;
- unsigned int TimerCount,SystemSpeed,SystemSpeedIndex;
- void InitialTimer2(void)
- T2CON = 0x00; //16 Bit Auto-Reload Mode
- TH2 = RCAP2H = 0xFC; //重裝值,初始值 TL2 = RCAP2L = 0x18;
- ET2=1; //定時器 2 中斷允許
- TR2 = 1; //定時器 2 啟動
- EA=1;
- unsigned int code SpeedCode[]={ 1, 2, 3, 5, 8, 10, 14, 17, 20, 30,
- 40, 50, 60, 70, 80, 90, 100, 120, 140, 160,
- 180, 200, 300, 400, 500, 600, 700, 800, 900,1000};//30
- void SetSpeed(unsigned char Speed)
- SystemSpeed =SpeedCode[Speed];
- void LEDShow(unsigned long LEDStatus) //修改處
- P0 = ~(LEDStatus&0x00FF);
- P1 = ~((LEDStatus>>8)&0x00FF);
- P2 = ~((LEDStatus>>16)&0x00FF); //修改處
- void InitialCPU(void)
- RunMode = 0x00;
- TimerCount = 0;
- SystemSpeedIndex = 10;
- P0 = 0xFF;
- P1 = 0xFF;
- P2 = 0xFF;
- P3 = 0xFF;
- Delay1ms(500);
- P0 = 0xFF;
- P1 = 0xFF;
- P2 = 0xFF;
- P3 = 0xFF;
- SetSpeed(SystemSpeedIndex);
- //Mode 0
- unsigned int LEDIndex = 0;
- bit LEDDirection = 1,LEDFlag = 1;
- void Mode_0(void)
- if(LEDDirection)
- LEDShow(0x000001<<LEDIndex); //修改處
- else
- LEDShow(0x800000>>LEDIndex); //修改處
- if(LEDIndex==23) //修改處
- LEDDirection = !LEDDirection;
- LEDIndex = (LEDIndex+1)%24; //修改處
- void TimerEventRun(void)
- if(RunMode ==0x00)
- Mode_0();
- void Timer2(void) interrupt 5 using 3
- TF2 = 0; //中斷標志清除( Timer2 必須軟件清標志!)
- if(++TimerCount>=SystemSpeed)
- TimerCount = 0;
- TimerEventRun();
- unsigned char MusicIndex = 0;
- void KeyDispose(unsigned char Key)
- if(Key&0x02)
- if(SystemSpeedIndex>0)
- --SystemSpeedIndex;
- else
- if(Key&0x04)
- if(SystemSpeedIndex<28)
- ++SystemSpeedIndex;
- else
- main()
- unsigned char Key;
- InitialCPU();
- InitialTimer2();
- while(1)
- Key = GetKey();
- if(Key!=0x00)
- KeyDispose(Key);
復制代碼 |
