查看: 4184|回復: 2
DSP28335移植usos2的工程代碼
ID:235368 發表于 2017-9-26 17:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
#include "..\OS\28335cpu\includes.h"
#include "F28335_example.h"                                // Main include file
// Determine when the shift to right justify the data takes place
// Only one of these should be defined as 1.
// The other two should be defined as 0.
#define POST_SHIFT   0  // Shift results after the entire sample table is full
#define INLINE_SHIFT 1  // Shift results as the data is taken from the results regsiter
#define NO_SHIFT     0  // Do not shift the results
// ADC start parameters
#if (CPU_FRQ_150MHZ)     // Default - 150 MHz SYSCLKOUT
  #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3)   = 25.0 MHz
#endif
#if (CPU_FRQ_100MHZ)
  #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2)   = 25.0 MHz
#endif
#define ADC_CKPS   0x0   // ADC module clock = HSPCLK/1      = 25.5MHz/(1)   = 25.0 MHz
#define ADC_SHCLK  0x1   // S/H width in ADC module periods                  = 2 ADC cycle
#define AVG        1000  // Average sample limit
#define ZOFFSET    0x00  // Average Zero offset
#define BUF_SIZE   360  // Sample buffer size
*                                               CONSTANTS
#define TASK_STK_SIZE  30
#define N_TASKS        2
OS_STK  TaskStartStk[TASK_STK_SIZE];
OS_STK  TaskStk[N_TASKS][TASK_STK_SIZE];     /* Tasks stacks                                  */
*                                           FUNCTION PROTOTYPES
#define          LCD_DATA        (*((volatile  Uint16 *)0x45EF))
#define          EN         GpioDataRegs.GPBDAT.bit.GPIO61
#define          RW         GpioDataRegs.GPADAT.bit.GPIO27
#define          RS         GpioDataRegs.GPBDAT.bit.GPIO60
#define  LOW  0
#define  HIGH 1
#define CLEAR_SCREEN        0x01                //ÇåÆáÖ¸áî£oÇåÆáÇòACÖμÎa00H
#define AC_INIT                        0x02                //½«ACéèÖÃÎa00H¡£ÇòóαêòÆμ½Ô-μãλÖÃ
#define CURSE_ADD                0x06                //é趨óαêòÆμ½·½Ïò¼°í¼ÏñÕûìåòƶˉ·½Ïò£¨Ä¬èÏóαêóòòÆ£¬í¼ÏñÕûìå2»¶ˉ£©
#define FUN_MODE                0x30                //1¤×÷ģ꽣o8λ»ù±¾Ö¸áî¼ˉ
#define DISPLAY_ON                0x0c                //ÏÔ꾿a,ÏÔê¾óα꣬ÇòóαêλÖ÷′°×
#define DISPLAY_OFF                0x08                //ÏÔê¾1Ø
#define CURSE_DIR                0x14                //óαêÏòóòòƶˉ:AC=AC+1
#define SET_CG_AC                0x40                //éèÖÃAC£¬·¶Î§Îa£o00H~3FH
#define SET_DD_AC                0x80
extern const uchar  WordLib16x16[]={
0x00,0x00,0x00,0x00,0x0F,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x0F,0xD2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x0E,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x02,0x83,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xE7,0xF6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xDF,0xEC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xBF,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0x7F,0xB8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x06,0xFF,0xB0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0F,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xFF,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1B,0xFF,0xF0,0x00,0x00,0x0D,0x98,0x0F,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0xFF,0xF0,0x00,0x00,0x09,0x90,0x0C,0xC0,0x00,0x00,0x00,0x00,
0x00,0xAC,0x00,0x57,0xFE,0xF0,0x00,0x00,0x26,0x08,0x03,0x83,0x00,0x00,0x00,0x00,
0x00,0xFF,0x00,0x7F,0xFE,0xF0,0x00,0x00,0x1F,0xFA,0x03,0xBD,0x00,0x00,0x00,0x00,
0x00,0xDF,0x00,0x77,0xFD,0x00,0x00,0x00,0x3D,0xFE,0x03,0x3D,0x00,0x00,0x00,0x00,
0x00,0xBE,0x00,0x77,0xFD,0x00,0x00,0x00,0x2D,0xB6,0x03,0xF5,0x00,0x00,0x00,0x00,
0x00,0x77,0x00,0x67,0xFD,0x00,0x00,0x00,0x29,0xB0,0x07,0xF4,0x00,0x00,0x00,0x00,
0x07,0x7D,0x83,0xFF,0xFF,0x00,0x00,0x00,0x3F,0xB4,0x07,0xFC,0x00,0x00,0x00,0x00,
0x07,0xFD,0x83,0xDF,0xFD,0x00,0x00,0x00,0x1F,0xBE,0x03,0xF4,0x00,0x00,0x00,0x00,
0x06,0xFD,0x83,0xBF,0xFB,0x00,0x00,0x00,0x3F,0xFC,0x03,0xF5,0x00,0x00,0x00,0x00,
0x05,0xFD,0x83,0x7B,0xFB,0x00,0x00,0x00,0x2F,0xF6,0x03,0xFD,0x00,0x00,0x00,0x00,
0x05,0xFC,0x82,0xFB,0xFF,0x00,0x00,0x00,0x2F,0xB0,0x03,0xFD,0x00,0x00,0x00,0x00,
0x1B,0xFF,0x01,0xFB,0xFF,0x00,0x00,0x00,0x2F,0xB0,0x0B,0xF3,0x00,0x00,0x00,0x00,
0x1B,0xFF,0x81,0xFB,0xF9,0x00,0x00,0x00,0x1F,0xB0,0x0B,0xC6,0x00,0x00,0x00,0x00,
0x1F,0xFD,0x81,0xFB,0xFE,0x00,0x00,0x00,0x3B,0x30,0x06,0xFE,0x00,0x00,0x00,0x00,
0x3F,0xFF,0x81,0xFF,0xF6,0x00,0x00,0x00,0x16,0xB0,0x0D,0x00,0x00,0x00,0x00,0x00,
0x3F,0xFB,0x83,0xFF,0xF0,0x00,0x00,0x00,0x0D,0xC8,0x03,0x80,0x00,0x00,0x00,0x00,
0x2F,0xF7,0x83,0xFF,0xF1,0xE0,0x00,0x0F,0x0F,0x78,0x07,0xFC,0x00,0x00,0x00,0x00,
0x2F,0xF0,0x03,0xF7,0xF1,0xA0,0x00,0x1B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x2F,0xE8,0x03,0xF7,0xE9,0x00,0x00,0x17,0x00,0x30,0x00,0x00,0x00,0x00,0x20,0x00,
0x7F,0xF8,0x01,0xF7,0xE8,0xFE,0x7E,0x0D,0x0F,0xD3,0xF8,0x3F,0xDF,0xFF,0x9F,0xC0,
0x7F,0xD8,0x41,0xF7,0xF9,0xFF,0xFE,0x2E,0x0F,0xD3,0xFC,0x7F,0xFF,0xFF,0xFF,0xE0,
0x3F,0xFF,0x71,0xEF,0xF9,0x39,0x98,0x2E,0x03,0xE8,0x64,0x4F,0x26,0x4E,0x67,0x20,
0x1F,0xAF,0xB1,0xEF,0xF8,0x3C,0x38,0x1F,0x05,0xE9,0x60,0x17,0xAE,0x8E,0x03,0x00,
0x1F,0xAF,0xF1,0xFF,0xD8,0x3D,0xB4,0x1F,0x45,0xF1,0x60,0x17,0xAD,0x0E,0x03,0x00,
0x1F,0xAF,0xB3,0xFF,0xD0,0x1F,0xB4,0x1F,0x45,0xF0,0x60,0x13,0xA8,0x0E,0x03,0x00,
0x1F,0xC9,0x8F,0xDF,0xF8,0x1E,0x6C,0x9F,0x45,0xFA,0x60,0x03,0xDA,0x0E,0x03,0x00,
0x1F,0xCF,0xFF,0xFF,0xB0,0x2E,0x64,0xB7,0x45,0xBA,0x60,0x05,0xFA,0x0E,0x03,0x00,
0x1F,0x4F,0xFB,0xBF,0xA0,0x2E,0xD0,0xB7,0x85,0xBC,0x60,0x05,0xF0,0x0E,0x03,0x00,
0x3F,0x49,0x8F,0xFF,0x60,0x0F,0xD0,0xF3,0xA5,0x9D,0x60,0x02,0xE0,0x0E,0x03,0x00,
0x3F,0x8F,0xB7,0x7F,0x40,0x07,0xC0,0xE3,0xA5,0x9E,0x60,0x00,0xF0,0x0E,0x03,0x00,
0x2F,0xBF,0xF7,0xFE,0xC0,0x07,0x80,0x63,0xA5,0xAE,0x60,0x06,0xF4,0x0E,0x03,0x00,
0x7F,0xBD,0xBE,0xFF,0xC0,0x07,0x80,0x7F,0xC5,0x8F,0x60,0x06,0xFE,0x0E,0x03,0x00,
0x37,0xB9,0xED,0xFD,0x80,0x03,0x80,0x7F,0xC5,0xB7,0x60,0x05,0xBA,0x0E,0x03,0x00,
0x7F,0xB9,0xDB,0xFB,0x80,0x07,0x82,0xC1,0xC5,0x97,0xE0,0x05,0xB8,0x0E,0x03,0x00,
0x6B,0xD9,0xB7,0xFF,0xC0,0x07,0x82,0xD9,0xE5,0x8B,0xE0,0x03,0x7C,0x0E,0x03,0x00,
0x3F,0xCE,0x6F,0xF7,0xC0,0x07,0x82,0xDD,0xED,0x8B,0xE0,0x03,0x5E,0x0E,0x8B,0x00,
0x37,0xF7,0xDF,0xEC,0x00,0x07,0x82,0xC0,0xED,0x81,0xE0,0x16,0x0E,0x8E,0x97,0x00,
0x3B,0x7F,0x3F,0xDC,0x00,0x33,0xB5,0xD2,0xED,0x93,0xE0,0x6E,0xEF,0x4F,0x06,0x80,
0x3D,0xBE,0xFF,0xBC,0x00,0x27,0x91,0xC4,0xF3,0xC2,0xE0,0xCE,0x4F,0x07,0x8F,0x80,
0x3E,0xFF,0xFE,0x7C,0x00,0x1F,0xE7,0xF3,0xFF,0xF0,0xE0,0xBF,0xBF,0xC3,0xFD,0x00,
0x3E,0x7F,0xFC,0xFC,0x00,0x1F,0xE7,0xF3,0xFF,0xF1,0x70,0xBF,0xBF,0xC9,0xFB,0x00,
0x13,0x3F,0xF3,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x90,0x00,0x00,0x00,0x04,0x00,
0x00,0xE7,0x9E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x03,0x9C,0x00,
0x00,0xF8,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x01,0x88,0x00,
0x00,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
extern uchar A[]={"ÄϾ©ÑDDñ"};
extern uchar B[]={"μçÆø¿Æ¼¼óDÏT1«Ë¾"};
extern uchar C[]={"www.armdsp.net"};
extern uchar D[]={"www.njyxdq.com"};
extern uchar E[]={"tel:02558747116"};
void LcdInit();
void WriteCmd12864(Uint16 cmd);
void WriteData12864(Uint16 dat);
void delay (Uint16 t);
void configtestled(void);
void InitXintf(void);
void DisplayCgrom(uchar *hz);
void Task(void *data);                              /* Function prototypes of tasks                  */
void Task1(void *data);
void OSTickISR();
void scic_echoback_init(void);
void scic_fifo_init(void);
void scic_xmit(int a);
void scic_msg(char *msg);
/*$PAGE*/
*                                                MAIN
interrupt void ISRTimer0(void);
interrupt void ISRTimer1(void);
interrupt void ISRTimer2(void);
//--- Global Variables
Uint16 AdcBuf[ADC_BUF_LEN];                                // ADC data buffer allocation
Uint32 PwmDuty;                                                        // Measured PWM duty cycle
Uint32 PwmPeriod;                                                // Measured PWM period
Uint16 p, x,y;
Uint16 LoopCount;
Uint16 ErrorCount;
Uint16 ReceivedChar;
char *msg;
void main(void)
        //--- CPU Initialization
        InitSysCtrl();                                                // Initialize the CPU
        InitPieCtrl();                                                // Initialize and enable the PIE
        //InitPieVectTable();
        InitWatchdog();                                                // Initialize the Watchdog Timer
//        InitGpio();                                                        // Initialize the shared GPIO pins
//        InitXintf();
    InitXintf16Gpio();
    InitScibGpio();
        configtestled();                                                // Initialize the external memory interface
#ifdef EXAMPLE_FLASH                                        // EXAMPLE_FLASH, if defined, is in CCS project options
//--- Copy all Flash sections that need to run from RAM (use memcpy() from RTS library)
// Section secureRamFuncs contains user defined code that runs from CSM secured RAM
/*        memcpy(        &secureRamFuncs_runstart,
                        &secureRamFuncs_loadstart,
                        &secureRamFuncs_loadend - &secureRamFuncs_loadstart);
//--- Initialize the Flash and OTP
//        InitFlash();                                                // Initialize the Flash
#endif
   DINT;
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
   EALLOW;  // This is needed to write to EALLOW protected registers
   PieVectTable.TINT0  = &OSTickISR;//ISRTimer0;//
   PieVectTable.USER11 = &OSCtxSw;//èÎÎñÇD»»Ä£ÄaÖD¶Ï óÃÖ¸áîasm("     TRAP #30")à′μ÷óÃêμÏÖ
   EDIS;    // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize the Device Peripheral. This function can be
//         found in DSP2833x_CpuTimers.c
   InitCpuTimers();   // For this example, only initialize the Cpu Timers
// Configure CPU-Timer 0, 1, and 2 to interrupt every second:
// 150MHz CPU Freq, 1 second Period (in uSeconds)
   ConfigCpuTimer(&CpuTimer0, 150, 1000);//3õê¼»ˉÎa1MSÖD¶Ïò»′Î ×÷ÎaOSê±Öó
   StartCpuTimer0();
// Enable CPU int1 which is connected to CPU-Timer 0, CPU int13
// which is connected to CPU-Timer 1, and CPU int 14, which is connected
// to CPU-Timer 2:
   IER |= M_INT1;
// Enable TINT0 in the PIE: Group 1 interrupt 7
    PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
// Timer 1 connected to int13 by yang
        XIntruptRegs.XNMICR.bit.SELECT= 0;
    LoopCount = 0;
    ErrorCount = 0;
    scic_fifo_init();           // Initialize the SCI FIFO
    scic_echoback_init();  // Initalize SCI for echoback
        OSInit();
        OSTaskCreate(Task1, (void *)0, (void *)&TaskStk[0][0], 1);                                             /* Initialize uC/OS-II                      */
    OSStart();
        EINT;   // Enable Global interrupt INTM
    ERTM;   // Enable Global realtime interrupt DBGM
                   while(1){
*                                                  TASKS
  msg = "\r\n\n\nHello YanXu!\0";
  OS_ENTER_CRITICAL();
    scic_msg(msg);
    msg = "\r\nYou will enter a character, and the DSP will send it back! \n\0";
    scic_msg(msg);
   OS_EXIT_CRITICAL();
  OSTimeDly(1);
   RS=LOW;
    delay(25);
   RW=LOW;
    delay(25);
   EN=LOW;
   LcdInit();
   delay(25);
   WriteCmd12864(CLEAR_SCREEN);
   delay(250);
WriteCmd12864(0x82);
delay(25);
DisplayCgrom(A);
  WriteCmd12864(0x90);
delay(25);
DisplayCgrom(B);
  WriteCmd12864(0x88);
delay(25);
DisplayCgrom(C);
  WriteCmd12864(0x98);
delay(25);
DisplayCgrom(D);
for(y=0;y<10;y++)
{delay(25000);}
   delay(250);
//  while(1){
           WriteCmd12864(0x32);
    delay(25);
    WriteCmd12864(0x36);
         delay(25);
for (y=0;y<32;y++)
  {  WriteCmd12864(0x80+y); //y
     delay(10);
     WriteCmd12864(0x80); //X
     delay(10);
  for(x=0;x<16;x++)
         WriteData12864( WordLib16x16[y*16+x]);
         delay(10); }
for (y=0;y<32;y++)
     delay(10);
     WriteCmd12864(0x88); //X
     delay(10);
  for(x=0;x<16;x++)
         WriteData12864( WordLib16x16[512+y*16+x]);
         delay(10); }
for(y=0;y<10;y++)
{delay(25000);}
{ Uint16 i;
  while(t--)
     for(i=0;i<200;i++)
void LcdInit()
    delay(2500);
        WriteCmd12864(FUN_MODE);
    delay(25);
        delay(25);
    WriteCmd12864(DISPLAY_ON);
        delay(25);
        delay(30);
    WriteCmd12864(AC_INIT);
   delay(20);
  //  Uint16 i=5;
    RS=LOW;
    RW=LOW;
    EN=HIGH;
           LCD_DATA=cmd;
//        while(i--);
    EN=LOW;
{ // Uint16 i=5;
    RS=HIGH;
    RW=LOW;
        EN=HIGH;
    LCD_DATA=dat;
//        while(i--);
    EN=LOW;
        while(*hz != '\0')
                WriteData12864(*hz);
                hz++;
        delay(10);
   EALLOW;
    GpioCtrlRegs.GPBMUX2.bit.GPIO60 = 0; // GPIO60 = GPIO60
    GpioCtrlRegs.GPBDIR.bit.GPIO60 = 1;
    GpioCtrlRegs.GPBMUX2.bit.GPIO61 = 0; // GPIO60 = GPIO60
    GpioCtrlRegs.GPBDIR.bit.GPIO61 = 1;
        GpioCtrlRegs.GPAMUX2.bit.GPIO27= 0;
    GpioCtrlRegs.GPADIR.bit.GPIO27 = 1;
//   GpioCtrlRegs.GPBMUX2.bit.GPIO54 = 0; // GPIO60 = GPIO60
// GpioCtrlRegs.GPBDIR.bit.GPIO54 = 1;
   EDIS;
void scic_echoback_init()
    // Note: Clocks were turned on to the SCIA peripheral
    // in the InitSysCtrl() function
        ScibRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
        ScibRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
        ScibRegs.SCICTL2.all =0x0003;
        ScibRegs.SCICTL2.bit.TXINTENA = 1;
        ScibRegs.SCICTL2.bit.RXBKINTENA =1;
              ScibRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 37.5MHz.
              ScibRegs.SCILBAUD    =0x00E7;
        #endif
      ScibRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 20MHz.
      ScibRegs.SCILBAUD    =0x0044;
        #endif
        ScibRegs.SCICTL1.all =0x0023;  // Relinquish SCI from Reset
// Transmit a character from the SCI
    while (ScibRegs.SCIFFTX.bit.TXFFST != 0) {}
    ScibRegs.SCITXBUF=a;
void scic_msg(char * msg)
    int i;
    i = 0;
    while(msg[i] != '\0')
        scic_xmit(msg[i]);
        i++;
// Initalize the SCI FIFO
void scic_fifo_init()
    ScibRegs.SCIFFTX.all=0xE040;
    ScibRegs.SCIFFRX.all=0x204f;
    ScibRegs.SCIFFCT.all=0x0;
// No more.
lab52-DSP_ucosii_run_in_flash_nonBIOS.rar
507.16 KB, 下載次數: 16, 下載積分: 黑幣 -5
收藏收藏2 分享淘帖 頂 踩
ID:235368 發表于 2017-9-26 17:10 | 只看該作者
工程里面有中文注釋,不是亂碼
ID:376511 發表于 2018-7-21 11:34 | 只看該作者
能夠學習一下不要積分不
