只需一步,快速開(kāi)始
查看: 3028|回復(fù): 0
startActivityForResult
ID:104287 發(fā)表于 2016-1-31 02:37 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
tartActivityForResult :
由Activity1啟動(dòng)Activity2->執(zhí)行Activity2->在Activity2中調(diào)用setResult和finish方法數(shù)據(jù)將返回Activity1并觸發(fā)onActivityResult函數(shù);
實(shí)例:
step1:在Activity1中定義全局標(biāo)志量
        private static final int REQUEST_CONNECT_DEVICE = 1;
step2:在Activity1中的按鈕事件觸發(fā)startActivityForResult
        Intent serverIntent = new Intent(Activity1.this,Activity.class);
        startActivityForResult(serverIntent,REQUEST_CONNECT_DEVICE);
step3:在 Activity2中定義變量名字用于數(shù)據(jù)回傳到Activity1
        public static String EXTRA_DEVICE_ADDRESS = "device_address";
step4:在Activity2中觸發(fā)setResut函數(shù)并調(diào)用finish方法傳回?cái)?shù)據(jù)
        Intent intent = new Intent();
        intent.putExtra(EXTRA_DEVICE_ADDRESS, address);
        // Set result and finish this Activity
        setResult(Activity.RESULT_OK, intent);//其中Activity.RESULT_OK是一個(gè)標(biāo)志,用于咋下一步在Activity1的接收中區(qū)分是那個(gè)setResult發(fā)送的數(shù)據(jù)
        Toast.makeText(SearchDevice.this,info , 1).show();
        finish();//調(diào)用finfish方法返回AActivity
step5:完成step4之后會(huì)自動(dòng)進(jìn)入Activity1中的nActivityResult函數(shù):
        public void onActivityResult(int requestCode, int resultCode, Intent data) {
                       switch (requestCode) {
                                        case REQUEST_CONNECT_DEVICE:
                                                    // When DeviceListActivity returns with a device to connect
                                           if (resultCode == Activity.RESULT_OK) {
                                                // Get the device MAC address
                                                      address = data.getExtras().getString(Activity2.EXTRA_DEVICE_ADDRESS);
