編譯時出現(xiàn)如下提示應怎么辦?要用什么版本的編譯器才可以?怎樣獲得?
*** Target 'ROBOT' uses ARM-Compiler 'V5.06 update 5 (build 528)' which is not available.
*** Please review the installed ARM Compiler Versions:
'Manage Project Items - Folders/Extensions' to manage ARM Compiler Versions.
'Options for Target - Target' to select an ARM Compiler Version for the target.
*** Rebuild aborted.
