查看: 7037|回復: 7
2015年電賽STM32程序 電流電壓采集
ID:511461 發表于 2019-7-23 09:49 | 顯示全部樓層 |閱讀模式
用了外設的LCD以及迷你版自帶的LCD兩種方案,以下是外設的程序
  1. #include "stm32f10x.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "adc.h"
  5. #include "timer.h"
  6. #include "stdio.h"
  7. #include "key.h"
  8. #include "lcd.h"
  9. #include "usart.h"
  10. #include "led.h"
  11. #include "dac.h"
  12. #include "pid.h"
  13. /* Private variables ---------------------------------------------------------*/
  14. extern __IO uint32_t ADC_DualConvertedValueTab[10][4];
  15. extern float b;
  16. float V[50] = {0},I[50] = {0},t[50] = {0},m[50] = {0};
  17. float Vaver,Iaver,temp ,Iaver1, Iaver2,Vaver2;
  18. float K = 800;
  19. u8 g_ADCflag = 0;
  20. u16 g_adc = 0;
  21. signed g_fbase = 30;
  22. u8 Iflag = 1;
  23. u32 a=0;
  24. u8 keyvalue=0;
  25. float Vsum = 0,Isum = 0,tsum = 0,msum = 0;
  26. float Vmin = 3.3,Imin = 0,tmin = 0,mmin = 0;
  27. float Vmax = 0,Imax = 0,tmax=0,mmax = 0;
  28. u16  dacval=2160;
  29. float dianya;
  30. u16 j = 0;
  31. u16 adcx;
  32. u8  string[]={"    "};
  33. u8  string1[]={"    "};
  34. u8  string2[]={"    "};
  35. u8  string3[]={"    "};
  36. u8  string4[]={"    "};
  37. u8  string5[]={"    "};
  38. void NVIC_Configuration(void)
  39. {
  40.                 NVIC_InitTypeDef NVIC_InitStructure;
  41.
  42.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);        //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
  43.
  44.                 NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;          //定時器2優先級最高
  45.                 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  46.                 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  47.                 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  48.                 NVIC_Init(&NVIC_InitStructure);
  49. }
  50. float ADaverage(u8 N)
  51. {
  52.                 float sum=0;
  53.                 u8 i= 0;
  54.                 for(i=0;i<10;i++)
  55.                 {
  56.                         sum = sum + (float)(ADC_DualConvertedValueTab[i][N]/4096.0 * 3.3);
  57.                 }
  58.                 return (sum/10.0);
  59. }
  60. int main(void)
  61. {
  62.                         delay_init();            //延時函數初始化
  63.                         uart_init(9600);                 //串口初始化為9600
  64.       Lcd_Init();                        //初始化OLED
  65.       LED_Init();
  66.              KEY_Init();                //按鍵初始化
  67.                         ADCs_Init();      //初始化ADC
  68.                         Timer_Init();  //20ms定時器
  69.                         NVIC_Configuration();          //設置NVIC中斷分組
  70.                         Dac1_Init();
  71.       PIDInit ();
  72.       PIDInit2 ();
  73.       LCD_Clear(WHITE);
  74.             BACK_COLOR=WHITE;
  75.       DAC_SetChannel1Data(DAC_Align_12b_R, 2160);//????0
  76.             while(1)
  77.                         {
  78.                                         LCD_ShowString(8,0,"pid:",RED);
  79.                                         LCD_ShowString(8,20,"temp:",RED);
  80.                                         LCD_ShowString(8,40,"Vaver:",RED);
  81.                                         LCD_ShowString(8,60,"Iaver:",RED);
  82.                                         LCD_ShowString(8,80,"DAC:",RED);
  83.                                         LCD_ShowString(8,100,"dianya:",RED);
  84.                                         LCD_ShowString(8,120,"Vaver2:",RED);
  85.                                         keyvalue = KEY_Scan(0);//讀取按鍵值
  86.                                         if(keyvalue ==KEY0_PRES)//設定電壓減1Hz  B5
  87.                                         {
  88.                                                  b=b-0.005;
  89.                                         }
  90.                                         else if(keyvalue ==KEY1_PRES)//設定電壓減1Hz  B3
  91.                                         {
  92.                                                 if(dacval>65)   dacval=dacval-65;
  93.             DAC_SetChannel1Data(DAC_Align_12b_R, dacval);//??DAC?
  94.                                         }
  95.                                    else if(keyvalue ==WKUP_PRES)//設定電壓減1Hz  B3
  96.                                         {
  97.                                                 if(dacval<4092)   dacval=dacval+65;
  98.             DAC_SetChannel1Data(DAC_Align_12b_R, dacval);//??DAC?
  99.                                         }
  100.                                         sprintf((char*)string, "%.3f", b);        //顯示電壓值
  101.                                         LCD_ShowString(74,0,string,RED);
  102.
  103.                                         adcx=DAC_GetDataOutputValue(DAC_Channel_1);//??????DAC??
  104.                                         LCD_ShowNum(74,80,adcx,4,RED);
  105.                                         dianya=(float)adcx*(3.3/4096);                        //得到DAC電壓值
  106.                                         sprintf((char*)string3, "%.3f", dianya);        //顯示電壓值
  107.                                         LCD_ShowString(74,100,string3,RED);
  108.
  109.                                         if(g_ADCflag==1)//采集到50個電壓電流值進行處理
  110.                                         {
  111.        Vsum = 0;Vmin = 3.3;Vmax = 0;
  112.        Isum = 0;Imin = 3.3;Imax = 0;
  113.                 tsum = 0;tmin = 3.3;tmax = 0;
  114.                 msum = 0;mmin = 3.3;mmax = 0;
  115.        for(j=0;j<50;j++)
  116.        {
  117.        Vsum = Vsum + V[j];
  118.        if(V[j] < Vmin)        Vmin = V[j];
  119.        if(V[j] > Vmax)        Vmax = V[j];
  120.        Isum = Isum + I[j];
  121.        if(I[j] < Imin)        Imin = I[j];
  122.        if(I[j] > Imax)        Imax = I[j];
  123.
  124.        tsum = tsum + t[j];
  125.        if(t[j] < tmin)        tmin = t[j];
  126.        if(t[j] > tmax)        tmax = t[j];
  127.
  128.        msum = msum + m[j];
  129.        if(m[j] < mmin)        mmin = m[j];
  130.        if(m[j] > mmax)        mmax = m[j];
  131.        }
  132.        Vaver =(Vsum - Vmin - Vmax)/48;//去最大值最小值后平均
  133.        Iaver =(Isum - Imin - Imax)/48;//去最大值最小值后平均
  134.        temp =(tsum - tmin - tmax)/48;//去最大值最小值后平均
  135.        Vaver2 =(msum - mmin - mmax)/48;//去最大值最小值后平均
  136.
  137.        Iaver1= Iaver * 0.913;
  138.        Iaver2=Iaver1 - 0.6317;
  139.
  140.        if(Vaver>1.52 || Vaver<1.48) K =K + outPIDCalc(Vaver);//計算電壓調制系數
  141.        if(K>990)                        K=990;//限幅處理
  142.        else if(K<300)        K = 300;
  143.
  144.        if(temp<2.95)
  145.        {
  146.        GPIO_SetBits(GPIOA,GPIO_Pin_8);
  147.        GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  148.        }
  149.        else if(temp>3.05)
  150.        {
  151.        GPIO_SetBits(GPIOD,GPIO_Pin_2);                                                  //PD.2 輸出高
  152.        GPIO_ResetBits(GPIOA,GPIO_Pin_8);
  153.        }
  154.
  155.        if(Vaver2>2.5)
  156.        {
  157.        GPIO_SetBits(GPIOC,GPIO_Pin_4);
  158.        }
  159.        else GPIO_ResetBits(GPIOC,GPIO_Pin_4);
  160.
  161.        sprintf((char*)string1, "%.3f", temp);                        //顯示設定電流值
  162.        LCD_ShowString(74,20,string1,RED);
  163.        sprintf((char*)string2, "%.3f", Vaver);        //顯示電壓值
  164.        LCD_ShowString(74,40,string2,RED);
  165.        sprintf((char*)string4, "%.3f", Iaver2);        //顯示電壓值
  166.        LCD_ShowString(74,60,string4,RED);
  167.        sprintf((char*)string5, "%.3f", Vaver2);        //顯示電壓值
  168.                 LCD_ShowString(74,120,string5,RED);
  169. //                                                          sprintf((char*)string, "%d", Iflag);                        //顯示設定電流值
  170. //                LCD_ShowString(100,110,200,16,16,string);
  171.
  172.        g_ADCflag = 0;        g_adc = 0;        //標志位置0
  173.                                         }
  174. //                                LCD_Clear(WHITE);
  175.                     delay_ms(40);
  176.                 }
  177. }
  178. void TIM3_IRQHandler(void)
  179. {
  180.         if ( TIM_GetITStatus(TIM3 , TIM_IT_Update) != RESET )
  181.         {
  182.                 if(g_adc < 50)//電流電壓采集
  183.                 {
  184.                         V[g_adc] = ADaverage(0);
  185.                         I[g_adc] = ADaverage(1);
  186.       t[g_adc] = ADaverage(2);
  187.                         m[g_adc] = ADaverage(3);
  188.
  189.                         g_adc++;
  190.                 }
  191.                 else if(g_adc >=50)
  192.                         g_ADCflag = 1;
  193.         TIM_ClearITPendingBit(TIM3 , TIM_FLAG_Update);
  194. }
  195. }
所有程序51hei提供下載:
2015 E-OLED.7z (223.08 KB, 下載次數: 107)
ID:1 發表于 2019-7-24 03:52 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:511461 發表于 2019-7-24 10:15 | 顯示全部樓層
電路原理圖就是第一張圖片,源碼也已分享,再補一個LCD的
ID:511461 發表于 2019-7-24 10:16 | 顯示全部樓層
這是迷你版自帶的LCD的程序
2015 E - LCD.7z
251.83 KB, 下載次數: 18, 下載積分: 黑幣 -5
ID:511461 發表于 2019-7-25 08:17 | 顯示全部樓層
這是STM32自帶的LCD
2015 E - LCD.7z
251.83 KB, 下載次數: 23, 下載積分: 黑幣 -5
參與人數 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎勵!
ID:420744 發表于 2019-7-30 10:06 | 顯示全部樓層
aaaaaa。 發表于 2019-7-24 10:15
圖有點模糊可以發成文件形式嗎
ID:696302 發表于 2020-3-10 11:53 | 顯示全部樓層
標記一下 等著學習~~~~~~
ID:574873 發表于 2020-3-10 15:16 | 顯示全部樓層
還是很強大的哦,標記下,以后學習
